Beat load-shedding with EcoFlow’s home backup energy solutions
Load-shedding has recently hit Stage 6 and shows no signs of slowing down, leaving many South Africans scrambling to find backup power solutions.
EcoFlow’s portable power stations are the perfect solution to keep your devices powered during load-shedding.
Since 2017, EcoFlow has provided its portable power stations, home backup power, and eco-friendly off-grid solutions to over 100 markets – including the US, Japan, China, Australia, and Europe.
In 2021, the EcoFlow Smart Home ecosystem broke the Kickstarter record for the most funded tech project on the platform and was later named one of TIME Magazine’s 100 best inventions of 2021.
Below, we highlight several of EcoFlow’s best products for South Africans.
RIVER Pro
The RIVER Pro is a compact, portable, battery-powered device with an AC output of 600W and a base battery capacity of 720Wh – expandable to 1,440Wh with an extra battery.
EcoFlow’s X-Stream technology improves the performance of this power station by supporting fast charging to reduce downtime and ensure your devices are always powered and ready for action.
The RIVER Pro is ideal for both indoor and outdoor use and is 30% cheaper than comparable fossil fuel-powered generators.
DELTA
The EcoFlow DELTA has been EcoFlow’s best-seller since it was launched and is the ultimate backup power solution for your home.
This is thanks to its first-of-its-kind two-way inversion technology that converts AC to DC power and vice versa.
It also offers six 1,800W AC outlets and safely charges up to 80% in under an hour with X-Stream fast charge to ensure you get as much charge as possible between load-shedding periods.
DELTA Max
The DELTA Max packs an impressive 2kWh capacity that is expandable up to 6kWh with DELTA Max Smart Extra Batteries.
It can power most home appliances, including heavy-duty devices that use up to 3,400W.
The DELTA Max charges up safely and rapidly from 0-100% in just 1.8 hours and can serve as a comprehensive home backup solution during a power outage.
Additionally, it can be monitored, controlled, and managed using the free EcoFlow app via a Wi-Fi connection.
DELTA Pro
The DELTA Pro takes powering your devices to yet another level thanks to its base capacity of 3.6kWh – expandable to a whopping 25kWh.
This will ensure your energy needs are covered in any situation – including even the higher levels of load-shedding.
The DELTA Pro boasts a 3,600W output that can surge upward to 4,500W, and this will power 99.99% of heavy-duty devices at your home, in the outdoors, or at work.
There are six different charging options for you to choose from – from renewable energy sources to traditional wall outlets.
DELTA Max 1600 + 400W Solar Panel
The DELTA Max 1600 + 400W Solar Panel bundle is the ultimate solution to keep your lights on during power outages.
This is because even during load-shedding, you can charge the DELTA Max with up to two EcoFlow 400W Solar Panels to provide you with maximum power input.
The DELTA Max is then equipped with a Smart Maximum Power Point Tracking (MPPT) algorithm that automatically detects the voltage and current input from the solar panels in real-time to provide optimal solar generation even during cold or cloudy days.
About EcoFlow
EcoFlow is an eco-friendly energy solutions company founded in 2017.
It was developed by a multidisciplinary group of engineers who combined years of experience and expertise in the battery industry to develop new innovations in portable power solutions.
It provides peace of mind to customers in over 100 markets through its DELTA and RIVER portable power stations and varied accessories.
EcoFlow’s mission is to reinvent the way the world generates, stores, and uses energy through creative, environmentally conscious innovation.
Click here to get your backup power solution from EcoFlow now.
Contact: April Zhong, Senior Integrated
