DStv Streama – Excellent entertainment without a satellite dish
DStv’s new More for You package gives you uncapped fibre, a Streama TV Box, and a DStv Compact subscription for only R699 per month.
This offers you great value for money and provides the added benefit of letting you watch DStv on any TV without needing a satellite dish.
All you have to do is plug the Streama into your TV and connect it to the Internet to stream all your favourite channels.
An added bonus is that the Streama supports up to 4K streaming – allowing you to watch your favourite shows in far higher quality than what’s available through “regular” TV.
This is supported by the speedy 25/10Mbps uncapped fibre connection that comes with the More for You bundle and ensures the Streama TV Box gives you the best DStv viewing experience possible, every time.
Viewing on-the-go
If you’re away from your More for You fibre connection, don’t stress – you can still use your Streama TV Box, as it works on any Internet connection.
This makes it ideal for when you go away on holiday, as you can easily take the device with you and keep up with all your favourite shows, series, and sports.
This portability also means you won’t need to worry about the costs of a new satellite installation if you’re moving homes.
All you will have to do is unplug your Streama, take it to your new home, plug it into your TV, and you’re good to go.
This is not possible with conventional satellite TV – making the DStv Streama Box the superior option for savvy South African viewers.
Use your favourite streaming services
The value doesn’t end there, thanks to the Streama supporting all your favourite “non-DStv” content.
This includes movies and series from the world’s most popular streaming platforms: Amazon Prime, YouTube, and more.
While you will still need to purchase separate subscriptions for these services if you don’t have them already, it is very convenient to access all of this content from a central hub.
Great price
When you consider the convenience of DStv’s Streama device, the vast range of content you can access through DStv Compact, and the benefits of high-speed uncapped fibre, the DStv More for You bundle is an excellent deal.
It works out to be significantly cheaper than purchasing these services separately, and gives you access to DStv without the need for a satellite dish.
