Presented by Syntech
Gizzu portable power stations – The easiest way to beat load-shedding in South Africa
 ·18 Dec 2023
Gizzu is a trusted name in South Africa’s portable power station segment and its range of Hero products are the easiest way for you to beat load-shedding.
As an affordable alternative to a costly solar or inverter power installations, the Gizzu Hero range offers many benefits to users.
As they are portable, they can easily be carried around your home to serve different needs at different times.
Alternatively, you can embrace a modular approach where you buy a portable power station for different parts of your home – based on your power requirements.
The portability of the Gizzu Hero UPS Power Stations also makes it easy to take them with you on your holidays or to a work office.
Big success
Gizzu’s Hero UPS Portable Power Stations have been a massive hit in South Africa as they combine the best prices with the most advanced specifications on the market.
Each Gizzu Hero UPS Portable Power Station has a LiFePO4 battery that can be recharged from 0% to 100% at speeds ranging from 1.3 to 2.2 hours, depending on the model.
Thanks to their LiFePO4 technology, these batteries also have exponentially longer lifespans of approximately 3,500 cycles – three-times the number of cycles you would get from a typical lithium-ion battery.
For context, if you were to completely discharge and recharge your Gizzu Hero UPS Portable Power Station daily, your battery would last for nearly 10 years under typical conditions.
Each Gizzu Hero Portable Power Station also comes with UPS functionality with 10ms switchover, and to protect the battery, Gizzu has kitted out its power stations with multiple safety features.
These features include a comprehensive battery management system, as well as short-circuit, over-current, over-voltage, under-voltage, over-load, and temperature protections.
Choose your Gizzu power station
Gizzu understands that different South Africans have varying power needs, and it offers several Hero UPS Portable Power Stations that provide power outputs, capacity levels, designs, and ports to meet your requirements.
We detail the Gizzu Hero range, below.
Gizzu Hero Core 512Wh/800W UPS Portable Power Station – R7,999
The Gizzu Hero Core is great for keeping a wide range of devices powered during load-shedding, such as routers, laptops, TVs, gaming consoles, and desktop computers.
It is also ideal for camping and holiday trips thanks to its compact form factor and robust build design.
The Gizzu Hero Core supports an 800W power output and offers a wide range of ports – including a 220V AC plug, two USB Type-A ports, three USB Type-C ports, one DC port, a car socket port, and an XT60 port.
Gizzu Hero Max 1,024Wh/1200W UPS Portable Power Station – R12,999
  • Coming soon…
If you need to power household appliances that draw more power, the Gizzu Hero Max is a great choice.
With its 1,200W output power, it can power an 800W microwave for over an hour, an electric drill for an hour, a washing machine for an hour, or a 55-inch LED TV for over six hours.
The Gizzu Hero Max features two 220V AC plugs, two USB Type-A ports, four USB Type-C ports, two DC ports, a car socket port, and an XT60 port.
It is also extremely compact, making it easy to pack up and take with you on business and leisure trips.
Gizzu Hero Pro 2,048Wh/2400W UPS Portable Power Station – R21,999
Large household appliances and power tools are no match for the Gizzu Hero Pro.
It is capable of powering electricity-hungry devices like hairdryers, air fryers, coffee machines, and washing machines with ease thanks to its 2,400W output power.
Alternatively, you can use its massive 2,048Wh capacity to run many of your smaller appliances simultaneously for several hours non-stop.
The Gizzu Hero Pro has two 220V AC plugs, two USB Type-A ports, four USB Type-C ports, two DC ports, a car socket port, and an XT60 port.
Gizzu Hero Ultra 3,840Wh/3600W UPS Portable Power Station – R39,999
The Gizzu Hero Ultra is the ultimate portable power station as it can run several high-draw appliances simultaneously thanks to its 3,600W output power
You will struggle to find a home appliance that the Gizzu Hero Ultra cannot power – even electric chainsaws, electric irons, and air conditioners are no match for it.
Thanks to its innovative wheeled design, it is also easy to transport the Gizzu Hero Ultra around your home – and it will even fit into most vehicles for use on trips and at events.
The Gizzu Hero Ultra has three 220V AC plugs, two USB Type-A ports, four USB Type-C ports, two DC ports, a car socket port, and an XT60 port.
Get your Gizzu Hero UPS Portable Power Station
Gizzu’s Hero UPS Portable Power Stations are now available both online and in-store across a wide list of retailers, including:
As a South African brand, Gizzu offers exceptional local support for all of its products in South Africa.
Click here to buy your Gizzu Hero UPS Portable Power Station.
