EcoFlow DELTA 2 Max – End load-shedding quickly and affordably
Loadshedding is only getting worse, making it essential that all South African homes have an effective backup power source in 2024.
However, installing a complex solar system can be expensive and time consuming.
Fortunately, there is a quicker and substantially more affordable solution – EcoFlow portable power stations.
Portable power stations can be moved around your home and connected to multiple appliances and devices as needed – while providing the charge you need to keep your key items powered during power cuts.
EcoFlow DELTA 2 Max
A standout power station highly suited to South African homes is the new EcoFlow DELTA 2 Max.
This industry-defining power station is now available in the country and is poised to revolutionize the local market.
The DELTA 2 Max’s massive 2,048Wh capacity is more than enough to power most common home appliances and devices throughout load-shedding, while its wide range of ports ensure you can connect laptops, TVs, Wi-Fi routers, smartphones and much more all at once.
A typical 55-inch LED TV is a good example. It uses 116W, and could therefore be powered for over 17 hours by the DELTA 2 Max.
In a real-life use case, however, you will be powering several appliances at once – and with its impressive capacity, the DELTA 2 Max can run these appliances with ease throughout each load-shedding outage.
Once load-shedding ends, your DELTA 2 Max can then be recharged from 0 to 100% in only 81 minutes using typical AC power.
This guarantees that your EcoFlow DELTA 2 Max will always be at full capacity before load-shedding kicks in.
Then, when load-shedding kicks in, the DELTA 2 Max boasts an impressive 20ms UPS feature.
This feature will keep appliances connected to the power station running seamlessly – even when they need to switch over from grid power to your DELTA 2 Max.
In addition to conventional wall outlet charging, you can charge the DELTA 2 Max using the power station’s two 500W solar input ports.
If you own EcoFlow solar panels, you can connect them to your DELTA 2 Max through these ports. Combining solar and AC charging reduces charge times to only 43 minutes for 0-80% charging.
Convenience
Your fully-charged DELTA 2 Max is designed to maximise EcoFlow’s patented X-Boost technology – which seamlessly handles output overloads of up to 3,100W without shutting down.
This combines with the DELTA 2 Max’s support for up to 13 simultaneous devices to ensure you can keep multiple appliances and devices running at once during load-shedding.
The DELTA 2 Max has also been designed to be quiet while running, with noise creation at low input and output levels of only 30dB – compared to the industry average of 45dB+.
A 5-year warranty then gives you peace of mind when buying the DELTA 2 Max for long-term use.
Get the DELTA 2 Max
The EcoFlow DELTA 2 Max is the ultimate power station for whole-home comfort and the ideal choice to keep the lights on when load-shedding strikes.
It is now available in South Africa and is a must-buy for anyone who needs a powerful, convenient alternative power source.
Click here to get your DELTA 2 Max portable power station.
