Eskom takes aim at households with solar
Eskom, South Africa’s embattled power utility, is pushing for significant changes to its electricity pricing structure, which would drastically increase the monthly costs for households using solar power.
These proposals, presented to the National Energy Regulator of South Africa (Nersa) as far back as January 2021, have been developed to raise fixed capacity charges and implement new service fees, which would largely impact customers consuming less electricity, particularly those relying on solar energy.
The cornerstone of Eskom’s proposal is to escalate network costs associated with transmission, distribution, and transformer upkeep, recouping these expenses through both variable and fixed charges.
While Eskom currently applies a mix of variable costs and fixed fees, the proposed system would pivot toward higher fixed daily charges.
This means that even those who use minimal Eskom electricity—or none at all—would face substantial monthly costs just to stay connected to the grid.
Solar households, which rely on self-generated power and consume less from Eskom, would therefore be disproportionately affected, potentially paying much more than they do now simply to maintain a grid connection.
Eskom argues that these increased charges are necessary to address the revenue shortfall caused by the growing number of South Africans generating their own electricity.
According to the utility, households with solar power generate most of their electricity during daylight hours, forcing Eskom to ramp up its output quickly during evening peak hours to meet demand.
Eskom claims that this abrupt rise in evening demand incurs additional operational costs, which it hopes to offset through the proposed tariff adjustments.
In addition to covering operational costs, Eskom’s proposed changes seek to retain financial viability as South Africa increasingly turns toward alternative energy sources.
By imposing higher fixed fees, Eskom would limit the incentive for households to disconnect from the grid, ensuring a continued revenue stream from those who consume less electricity.
Energy Expert and Consultant Ted Blom commented on Eskom’s financial and operational policies, providing context on why Eskom would want to retain customers on the grid to sustain revenue streams.
He and other experts suggest that Eskom is also attempting to remain competitive against private generation, aiming to make its electricity offerings more financially attractive than the setup costs and maintenance of independent solar power systems.
This approach would effectively tie solar users back into the Eskom grid, as they would pay a premium if they tried to reduce dependency on the utility.
Energy Analyst Chris Yelland has also previously noted how fixed charges might discourage self-generation.
As it stands, Eskom acknowledges that these proposed fixed charges would significantly impact low-consumption users, including those with solar installations.
In its latest tariff revision, Eskom conceded that households using less than 900 kWh per month would face considerable cost increases.
To alleviate some of the immediate financial impacts, Eskom has suggested a phased approach with a 50/50 split between fixed and variable charges.
Over time, however, the fixed fees would gradually encompass 100% of the generation capacity charge, meaning users would be fully subjected to higher costs regardless of how little power they draw from Eskom.
Although this phased structure offers a short-term buffer for lower-usage customers, it ultimately represents a substantial price increase for all, especially solar users.
Energy economists such as Grové Steyn argue that Eskom’s reluctance to loosen its grip on low-consumption households stems from its financial struggles and operational inefficiencies.
As Eskom grapples with debt and technical challenges, it relies heavily on income from a broad base of customers, including those who might otherwise turn fully to solar or other self-generation options.
By discouraging households from going off-grid through hefty fixed fees, Eskom seeks to mitigate revenue loss and keep as many customers as possible financially tethered to its services.
A recent analysis by MyBroadband shows the potential impact of these tariffs on Eskom customers.
Households consuming no electricity could see a 321% increase in their bill, while those using only 100 kWh per month might face a monthly cost hike of approximately 130%.
This restructuring would affect most low-consumption users, even those who carefully conserve energy or generate most of their own power.
Although Eskom has yet to finalise and publish its updated tariff plan for 2024/25, the utility has shown no indication of altering its approach to fixed charges.
These pending changes have not yet received regulatory approval, but if enacted, they could reshape the financial landscape for South African households relying on solar power.
Eskom’s strategy underscores the complex balance between financial sustainability for the utility and the growing push for energy independence among South Africans.
As these proposed changes proceed toward potential implementation, they continue to draw widespread scrutiny from consumers and energy experts alike, reflecting the challenges and tensions inherent in South Africa’s energy transition.
