Solving the Eskom problem
 ·26 Mar 2019
Restructuring Eskom into separate functions is a sensible solution to many of its problems, says Mzukisi Kota, a Partner at Webber Wentzel.
“We believe it can be done in a way that should be acceptable to unions, but will not prejudice its lenders and the sovereign debt rating.”
Economists are divided on what Moody’s Investors Service will do when it potentially makes an announcement on South Africa’s credit assessment Friday.
Half the participants in a Bloomberg survey expect it to maintain a stable outlook on its local- and foreign-currency debt, with the remainder predicting a reduction to negative.
Many of those who foresee no change say there may be a move after the 8 May general election, however, the most immediate concern is Eskom, and it’s impact on  the country’s economy amid  a return to rolling power cuts.
The next step after the minister of finance’s announcement that vertically integrated Eskom will be split into its three functions – generation, transmission and distribution – will be a difficult one, said Kota.
“It entails finding the most effective and practical route to achieve the split, in a way which is acceptable to all stakeholders, particularly the labour unions.”
According to Webber Wentzel, it is clearly necessary to split Eskom up into separate business units.
“Despite the fears of the trade unions, this does not necessarily entail privatisation, certainly not in the short term, nor that there will be inevitable job losses, as the same functions must still be performed – assuming the separation does not reveal costly inefficiencies.
“Depending on how it is structured, such a split need not require new legislation,” Kota said.
Webber Wentzel pointed out that restructuring the country’s power utility would be in line with moves by other countries including the UK, parts of Europe, Kenya and Uganda, which have also split their power utilities into separate entities.
It further noted that an attempt to restructure the entity was made in 2012 when the Independent System and Market Operator Bill (the ISMO Bill) was introduced.
“It went through various modifications, but the general intention was to create an external entity that would own the transmission infrastructure and buy electricity from various generators, including Eskom, to sell to distributors.
“The rationale was that if Eskom was no longer both player and referee, electricity tariffs could become more transparent and competitive,” the firm said.
A version of the ISMO Bill was recently introduced by a private member in Parliament, it said. This version envisions some privatisation of the ISMO.
“It is not clear to us that the ISMO Bill can succeed in this present form. While it is arguably desirable to split generation from transmission (which refers to the long-distance power lines) and distribution (which refers to the last mile from substations to homes), transmission is capital-intensive and return on capital is low.
“Remote rural areas with poor communities are unable to pay cost-reflective transmission tariffs,” Webber Wentzel said.
In South Africa, the situation is complicated by the fact that Eskom’s sources of power, like coal in Witbank or the Waterberg or intense solar radiation in the Northern Cape, are far from its industrial areas – so lengthy transmission lines are needed, said Kota.
“There may be policy reasons to locate generation in particular areas, so it is better that transmission be driven by policy, rather than commercial considerations,” the legal partner said.
He continued that while separating Eskom into its component parts would not in itself address its excess debt, it may be a step in the right direction as it would create more transparency. If each business unit accounts and reports separately, it would become evident which units are profitable and which are loss-making.
“It would also be easy to see whether private sector generators were paying the same transmission charge as Eskom generation or whether there are any suboptimal anti-competitive behaviours in the settling of transmission (on wheeling) charges,” Kota said.
Separate accountability is also important for the tariff-setting process in which Eskom engages with the National Energy Regulator of SA (Nersa).
The tariffs set are, to a large degree, based on the projected needs of Eskom’s various operating entities, the firm said.
“During past financial crises, Eskom has sometimes had to divert funds granted by Nersa for one purpose to another business unit to address more immediate needs. This renders the tariff setting process somewhat illusory and of little benefit.”
From a regulatory perspective, there are broadly two mechanisms to implement an Eskom restructuring, Kota pointed out.
The first is to enact a new law creating the required separate entities (either two or three). This would follow the ordinary legislative process and require a lot of political support to succeed.
The second is to use the existing Eskom constitutional framework to restructure it into various entities such as an Eskom holding company with two or three subsidiaries.
“This second mechanism, while still requiring the support of stakeholders such as the trade unions and the lenders, has the benefit of not being as directly dependent on the political will of the entirety of parliament,” Kota said.
“If there is any hope of achieving the restructure without a lengthy delay, then it seems to us that the second option would be the one that makes the most sense.
“An important consideration here is the fact that the existing Eskom legislation (the Eskom Conversion Act) effectively provides that Eskom’s balance sheet is available to secure its debt.”
According to Kota, if the restructure results in Eskom having a group structure with the business units as separate subsidiaries, it may be possible to convince the lenders to take their security at group level and not treat the restructure as an event to default under the debt covenants.
“This would remove the dilemma of how to apportion the debt obligation among Eskom’s various constituents, as the debt could remain in the holding company.
“It is essential to avoid any default on Eskom’s bonds, which are held by a wide range of investors, both domestic and foreign, because it would seriously damage SA’s sovereign credit rating,” said Kota.
Read: Economists split on South Africa avoiding Moody’s negative cut
