Learn about NETGEAR’s debut of its purpose-built switches for audio/video applications
NETGEAR has launched an entirely new series of switches designed and built from the ground up for the growing audio video over IP (AV over IP) market.
Dubbed the AV Line, these products combine years of networking expertise with best practices from leading experts in the professional AV market.
“Pro AV customers don’t have to settle for an IT-centric interface with settings and IT-specific functionality they will never need.
The new M4250 AV interface presents the common AV controls right up front with user-selectable profiles for common AV platforms making it a snap to ensure the settings are correct for a specific audio or video application,” says Tobie van Schalkwyk, product manager for NETGEAR at Duxbury Networking.
The M4250 line of switches also supports more advanced configuration and a robust set of features for many different types of installations.
The industry-leading NETGEAR web-based IT GUI along with console, telnet, and SSH connections and a standard, out-of-band Ethernet port are all available for deeper settings adjustments.
Additional features include static, RIP and PIM routing, DHCP server and PTPv2.
One of the many features designed into the new M4250 product line is full support for Audio Video Bridging (AVB), an industry standard for transporting content over a network.
AVB is used most often when very low latency is required such as in live performances when lip sync is critical. All of the AV Line M4250 switches can be optionally licensed for AVB support.
Codecs for transporting AV signals over a network are generally identified based on bandwidth requirements: 1 Gbps or 10 Gbps per stream.
The new AV Line of M4250 switches targets the widespread 1 Gbps codecs giving installers a much wider range of AV-over-IP applications than ever before.
The M4250 switches are designed for a clean integration with traditional rack-mounted AV equipment.
A sleek, black display panel provides port and activity status in the front, with all power and network cabling neatly organised in the back.
However, when ports are desired on the front of the rack, reverse rack mounting is possible with an included pair of recessed rackmount ears that allow room for the cabling.
Additional options for mounting outside the rack are available with universal, threaded holes located on the bottom and the front of each switch.
The switches launching as part of the AV Line series range from 8 to 48 ports with a variety of PoE+ (30 W per port) and Ultra90 PoE++ (90 W per port) options.
In addition, uplink choices include 1 G for audio installations or standalone video installations as well as 10 G uplinks for larger scale video deployments.
The AV Line M4250 series also includes 12-port multi-gigabit Ethernet and 16-port 1G/10G fibre models for plug-and-play aggregation in a totally automated star topology.
“Until today, AV professionals had only a few suitable options for network switches; they had to use IT-based products and learn how to make them work – resulting in a lot of frustration,” says Van Schalkwyk.
“NETGEAR has collaborated intensively with the Pro AV world to better understand the challenges they face.
The result is this new AV Line of M4250 switches with out-of-the-box functionality and an industry-first concurrent second user interface solely designed with the AV Pro in mind.”
Software-controlled fan adjustments enable the fans to be turned off when ambient temperature and Power-over-Ethernet (PoE) loads are appropriate for fanless operation of the M4250 switches.
For use in sound-sensitive environments such as conference rooms, recording studios, and residential installations, this powerful feature provides new opportunities for the AV Line switches to be deployed.
The new AV Line of M4250 switches maintains the same thorough out-of-the-box functionality found on the M4300 and M4500 switches for almost all AV-over-IP encoders and decoders.
Pre-configured with NETGEAR IGMP Plus, the M4250 switches can simply be plugged in and turned on, making multicast setups a breeze.
Setup and installation time are greatly reduced, allowing the installer to focus on other parts of the project – NETGEAR has taken care of the multicast presets.
“The NETGEAR M4250 series switch is a great solution for A/V related projects that are network centric,” said Van Schalkwyk.
“This switch line provides an easy to use wizard which greatly simplifies device configuration.
This wizard promotes consistent configurations that match up with industry best practices requiring minimal effort from technicians or engineers in the field.”
The NETGEAR ProSAFE Limited Lifetime Hardware Warranty on the M4250 series is an example of the commitment to the Pro AV community.
This comprehensive package includes 90 days of technical support via phone and email, lifetime technical support through online chat, and lifetime next business day hardware replacement.
All NETGEAR Pro AV customers can take advantage of free design services as they design and deploy professional audio and video solutions which require IP networking infrastructure.
This dedicated Pro AV Engineering Services team of experts spread around the globe helps empower designers and installers of AV over IP systems through free network design assistance, training, and installation support.
“In order to introduce customers to the benefits this range offers, Duxbury will be hosting a webinar, led by Richard Jonker – NETGEAR VP Business Development, AV over IP, EMEA – on 11 August 2021 from 10:00 to 11:00 SAST (South African Standard Time).” says Van Schalkwyk.
Click here to register for the webinar.
For more information contact Duxbury Networking, +27 (0) 11 351 9800, [email protected], www.duxbury.co.za
